Re: Digital Fuel Gauge
Here's one way to display fuel levels on your Raymarine unit using their proprietary SeaTalk ng backbone system: Set up the SeaTalk ng backbone system. Using a drop down T-connector (or a 5-port hub) add a Raymarine "device net" drop down cable. This will connect directly to the programmable Lowrance EP-65R fluid level sensor (not the EP15 - this is a red/blue male/female Lowrance connector issue). Connect the EP-65R sensor to your fuel tank's sending unit. Here's the catch: you must then program the EP-65R with a Lowrance head unit, which must be connected temporarily to the SeaTalk ng backbone and removed when programming has been completed. I found a professional who had a Lowrance head unit do the programming for me. You might find a volunteer if you ask around. It is true that the accuracy of the digital data is only as good as the fuel tank's sending unit, but if you have the time and inclination, you can program the EP-65R as you fill your tank to dial it in.
