I bought a '96 Grumman Fun Ship this year. The boat was wired with a toggle switch in the left-most slot (Accessory 1) on the console to work the anchor winch in the front of the boat. The switch isn't working, so I looked underneath to see if a wire was disconnected/broken.
To my surprise, the original Accessory 1 switch in that slot was still in the console. It was switched off but hooked up to a bunch of wires in each of the terminals (almost looks like it is rigged up as a junction). When I switched it on to see what it controlled. The switch's light came on, but there was no obvious activation (or deactivation) of other things in the boat. I switched it back off and haven't traced down the anchor winch problem yet. Also, I can't seem to figure out what the Accessory 2 switch is hooked up to.
Does anyone else have a funship that knows what these are supposed to be used for?
