jjay74
- Jul 8, 2007
- 46
Need a little help here.....I have a Larson 1550 Shark Tri Hull. The navigation lights aren't working. I can access the anchor light with no problem and will have no problem fixing it. The bow light is missing off the front and it mounts on the very front.
I understand how to wire the lights and switch, but I am having a problem coming up with how in the heck to run the wires from the front to the dash panel. There are absolutely no access holes in the bow area, other than the 1/4 inch hole that is already drilled for the wires to drop in.
Under the dash, there is an access hole all the way to the right on the starboard side that I can barely reach my hand into. I am stumped on how to pull a wire from the front to the dash without cutting more holes in the boat. I thought about using a coat hanger to "fish" it in there, but there is no way to bend and maneuver a coat hanger through the 1/4 inch hole that is already there.
Please help.
Please help.
