Re:Rocker Switch Wiring NAv/ANCHOR lights
Hello Silvertip!
Actually my switch is an ON-OFF-ON position since its for Nav/Anchor lights and its have 6 terminals in the back. Just did a research over the net and it maybe goes like this: the middle one goes the power, upper terminal power for nav light, down terminal power for anchor. If you provide power to the middle terminal at the right or left side you should use the same terminal side.
I found this diagram here at iboats but I get confuse
with the "bridge" at the right side of the terminal. please take a look. I believe that only need to add pos. wire of the anchor light at the same side of the pos. (+12v) live wire, I mean in the 3rd connector of the left side.
What you think?
