Expidia
- Aug 26, 2006
- 2,328
So I gave my Hotmaps Premium SD card to my Daughter to use in her new Humminbird 587 CI combo fishfinder / GPS. I figured I'd snag another one off Ebay and get one a year or two newer.
Here is what I found out on how the various years are price out there and the difference between them.
I needed a Hotmaps "Premium" card. (premium denotes that years latest maps and features) Hotmaps alone means last years maps. So a 2008 Hotmaps card is actually the card that came out in 2007.
I spoke with a Navionics rep last week because I read threads on the Texas fishing forums that some members had purchased the Navionics Hotmaps for their area and the latest cards in 2009 had less detail (under water structure) then their older cards! They were complaining their 2009 lake maps only showed the outline of some lakes where the year before 2008 of the the same lake had full detail.
So for example, the 2010 Hotmaps card for the East region is actually just the 2009 card. When it says 2010 premium you are buying the latest version with more HD surveys. They MSRP at $149 and can be found for around $125 online.
Hotmaps and Hotmaps Premium work in most Navionics compatible units.
Hotmaps Platinum only work in certain units that can show their 3D and aerial views on some lakes. My other hummingbird 797 C2 SI (side imaging) was $999 and that still does not work with Platinum cards.
In 2009 they lost some of the data rights. Their contracts ended with some of the vendors who supplied them with bottom contour and structure detail on certain lakes. So the rep told me that in 2009 there was less detail. 2010 Hotmaps Premium had more detail than 2009 and was more accurate. Their issues were in 2009 from buying map data from other sources that showed under water detail, but the detail like structure was not that accurate as to exactly where it was showing up on the map and if it was actually there at all. Now they survey many lakes with their own fleet of boats.
So bottom line it's a trade off as to how accurate in detail the cards were in 2009. 2008 had more detail, but it's not as accurate as 2010. 2010 is the most accurate.
I just won by bidding a 2008 Hotmaps premium card off Ebay for $104 new in a sealed package. My old one I gave away was the 2007 Hotmaps Premium. Each year they throw in a few hundred more lakes and increase more lakes with HD detail.
The 2010 SD card is actually a micro card that comes with an SD adapter to fit the SD slot.
So don't get caught up seeing certain cards on Ebay looking like a great "buy it now" price. Many stores are trying to dump the 2009 cards and the 2008's are in high demand because that was the last year with the most detail. The rep said the 2010 Hotmaps premium cards are also good and they are also their latest and cost $125-150. Don't get caught up bidding for the 2010 Hotmaps only card, because it's really the 2009 version.
Cabala's used to have the best deal. At the end of the season they used to put last years cards on clearance for $59.95.
Be real careful of buying used or off Craigs List because Navionics protects their cards and if someone tries to copy the card, it's toast. I'd only buy an unopened sealed package or by used from someone you know or from a reputable store.
I've been trying to understand how Navionics markets their cards. The first one I bought was in 2007 and I paid $149 for the Navionics Gold East SD card. I'll sell it on Ebay since these used cards are in high demand and it was not the one I wanted. It was actually the Marine version which showed all the bottom contours on the coastlines on the East coast from Maine to FL. It does show some inland waterways too like in my region the Hudson River and Lake Champlain. That's what I thought I needed, but I found out after I bought it what I really wanted was Hotmaps Premium version which is the inland lakes version with 12,000 lakes over various eastern states, plus lake bottom contours and structure and it also tells you where various fish species hang out.
So I hope this Navionics 101 primer helps.
Posters welcome to correct any in accuracies I might have said about the map cards . . .
That's it, that's all and that's my story and I'm sticking to it
