Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Lowrance 3500 Depth Gauge
  • Lowrance 3500 Depth Gauge
    I need a replacement Lowrance 3500 Depth gauge (digital reeadout). Mine is losing the readout on the the number from 10' and up. I know they are discontinued, but I don't want to try to snake a new cable from the flybridge to the bilge and certainly don't want to cut a hole for a new transducer. The old guage uses a puck that reads through the bottom of the hull.
    Anyone have any idea where there might be a gauge available, with or without transducer? Any help is greatly appreciated.
    2001 Carver Voyager 374 'Stick's Competition'
    Something tells me I should be on the water....
    If I answer your upholstery questions, it's only because I've been doing it 20+ years...
    Re: Lowrance 3500 Depth Gauge
    I have a similar issue. How did you solve your problem? Did you find a unit compatible with the Lowrance 192 kHz transducer?
    How hard will it be to replace that in-hull piece?
    • #3
      I found a leftover on the internet for $75.00. I replaced the gauge and sold the new unused transducer on the internet for $45.00. There are more out there. Just keep looking.
