PSDEERHUNTER
- Jan 7, 2010
- 1
I have a Zercom LCF 40 flasher for ice fishing.My problem is the plug that you plug the transducer into, one of the little prongs broke off.
I tried to contact Hummingbird for a part they don't fix that unit any more.
I took the unit apart and does anyone know what this part is called.I pulled it off the board, inside the unit.It is the plug that has 3 little pins that the transducer plugs into. then a wire that is splice into 3 wires a blue and 2 back wires that goes into a little red conector that pugs into the board inside the unit.
Anyoneone know what this part is called or where I can order one.
Thanks
Thanks
