Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Pics: My bow mount trolling motor install
  • Pics: My bow mount trolling motor install
    I recently purchased a Minn Kota 60lb 24v trolling motor. My tri-hull doesnt have the best available area on the bow to mount the motor so I did my best.
    I elected not to mount it at an angle going along the curve of the bow because I would have had to drill through where the teak wood slats are on the bow. Instead, I went with a more straight mount that does block the starboard bow seat when the motor is stowed. I'm not too worried about this because I don't allow anyone to sit in that seat when I'm steering the boat anyway. I used a piece of Ipe hardwood as the mounting plate.
    Four bolts with large washers are going through the bow and bolting underneath into where the anchor is stowed. I used large 1 1/2 inch washers to provide additional support where mounted. There is existing plywood support underneath of the fiberglass cap so there is plenty of support strength. The motor is very secure and doesnt move at all.
    Comments, suggestions, critics are welcome.
    Thanks for looking
    1979 Cobalt 18TH
    OMC 260 Engine(GM 5.7L V8)/OMC 800 Hydro-Mechanical Stringer Drive
    A picture is worth a thousand words. Having a problem? A picture will get you more responses.
    Re: Pics: My bow mount trolling motor install
    I think you have found an excellent solution!
    Often Wrong,
    but never in doubt!
    • #3
      Edit/Delete: (didn't catch that you made it out of ipe, thought it was particle board )
      Looks good to me.
      2001 Crestliner SuperHawk 1800, Mercruiser 140HP
      2007 Tracker 1436 jon boat, 7.5HP Force
      • #4
        I like your ideas , they are helping me with a similar issue . peter
