Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
help me wire an illuminated rocker switch
  • help me wire an illuminated rocker switch
    I am trying to wire a 2 position 3 prong illuminated rocker switch. It is made by seachoice and the package reads 2 position off-on (red). I take that to mean that the switch is lit when on and unlit when off. I can make the switch operate the component that I am wiring it to, but it will not illuminate. the switch has 2 prongs on one end numbered 1 and 4 and then one prong down the side numbered as 2. I have wired the positive wire to one of the end prongs and the negative on the side prong and the device works but yet the switch will not illuminate. What am I missing? Should there be a third wire connected to the other prong ? Thanks...Darren Mac:
    Re: help me wire an illuminated rocker switch
    You described hooking up power to one tab, ground to another...you have the load that is being switched on the third right?
    1998 Wellcraft Eclipse 24 Cuddy
    Volvo Penta Duo-Prop 7.4L "LK"
    2006 Sun Tracker Party Barge 21
    Mercury 90 4-Stroke FI
    "Common sense is not very common"
    "Failing to prepare is preparing to fail." -- John Wooden
    • #3
      Nope , I was treating it as a simple circuit. This isn't my thing obviously . I suppose I should treat the other terminal as my load and ground my device back to the main ground. Is that right?
      • #4
        One of the tabs is for the ground. One of the tabs is for 12v. The last tab is for your load. I have a feeling you are calling your load your ground which is not correct.
        The back of the package should show the pinnouts.
        • #5
          What do you mean by "device"...that your switch? Is device and load the same thing the way you are describing it?
          • #6
            I know this isn't your exact switch but 12V goes to 2, your load goes to 3 and your ground goes to 7.
            If you wire up 2 and 3 backwards, your light will be on all the time so just reverse. The ground on your switch will more than likely be the tab furthest from the other 2.
            • #7
              Yes , that does sound like what I am doing. My device is a simple courtesy light with 2 wires, red and black. I had put the light in series with the switch thinking the 12 volts would also illuminate it. This circuit is straight wired through a fuse to a battery. I had made up a circuit with my wires before I install it in my boat. What would the proper way to wire this be. Should I put my red wire on a load terminal and then put my black wire also back to my ground on the battery via a splice maybe?
              • #8
                viewed from the back holding the switch up right.
                Top: 12+
                Middle: Load
                Bottom: Ground
                2011 Triton 190 Escape SE 150 Mercury Pro XS
                I never learned much from winning, but always learn from failure.
                Semper Fi
                • #9
                  Holding my switch upright I have 2 pins on top numbered 1 and 4. I have one pin down on the side of the switch numbered as 2. I have a positive wire from the battery and a negative wire. My light I want to install has a red and a black wire. And I want my switch to illuminate when on. What do I do. I am trying to understand please help
                  • #10
                    Ok:
                    1: 12v+
                    2: Load
                    4: not sure.
                    If it doesnt work then change the load to #4
                    run 12v+ to #1 and then the load off #2. also from #2 run a wire to the red wire on the light and the other light wire to ground.
                    this will cause the light to run when the switch is on.
                    Semper Fi
                    • #11
                      I hate to see folks struggle with this stuff when the solution is so simple. Here ya go. The terminal numbers on this diagram may or may not match yours. But the key terminal is the ground terminal on the switch. Look for the ground symbol. That terminal is NOT the ground terminal for the device, it is the ground terminal for the lite in the switch.
                      • #12
                        Silvertip, Thanks for coming out of retirement to help a fellow boater.
                        YOU ARE THE MAN!!!!
                        I've never made a mistake in my life. I thought I did once, but I was wrong.
                        • #13
                          When I said I was hanging it up I didn't mean I was going to pop a cold one, sit in my Lazy Boy and wait for the Grim Reaper to come-a-knockin'! I'm simply not going to be as active on the forums as I once was.
                          • #14
                            Silvertip, As much info as you have put onto this site is amazing... you are truly a generous and selfless man.
                            Back to Top
