Stator wiring to extra wire on 1985/85hp force
shawpdx1
this thing is driving me crazy! I don't want to through money at it. I have spark at the 2 top cylinders none at #3 I have switched connections and get spark from that # 3 coil off the other CDI. Im wondering if its my CDI that is bad or my stator. I have a good ground everything is daisy channed to the block I know there is and extra wire or side of the CDI that could be good how do I go about swapping to that lead? I know you have to switch more then just one wire. any help would be appreciated
j_martin
Re: Stator wiring to extra wire on 1985/85hp force
Maybe if you put this query in the Force engine forum..........
you might get some attention.
