I have a Lowrance LCX-111c HD, along with a LGC-2000 GPS Module. I just upgraded the software on the LCX from 1.4.0 to 2.1.0 and the GPS module to 1.9.0. It seems to have reset a bunch of my settings. I have Navionics Gold Maps (from 2006). ((how often should these be upgraded BTW))
I selected Navionics (MMC/SD) in the Map Dataset Choice select menu, but I can no longer see the water charts/depths like I used to. I went through the system settings and it's set to feet, farenheight, etc. correctly.
My sonar also seems to look a lot different than it did before:
Can anyone spot what the problem is? Does anyone know of a guide online that shows how to optimally set everything in my GPS/chartplotter? There's just so much info and being new to this I'm not sure which settings are best.
Any help would be greatly appreciated.
