Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
minn kota problem
  • minn kota problem
    i have a minn kota maxxum 74 pound thrust, broke the skeg off, took it apart had the skeg re-welded , put the foot back to gether and the prop will spin one time and then you can just hear it hum
    what did i do wrong? the prop when you spin it by hand does not spin freely, take it back apart and can find no "binding" problems (or that I can see)
    let me know what I did wrong
    thanks
    Re: minn kota problem
    If you broke the skeg, you hit something hard. When you hit something hard you probably bent the shaft. Run the motor with the prop off at slow speed. Watch the end of the shaft very carefully. If it wobbles you have a bent shaft. when you put the prop on it binds every revolution.
    • #3
      the skeg was broken off when loading on the trailer, the foot/prop never hit anything, but Im with you I think the shaft must be bent but it will not turn but 1/2 turn before it stops again, must be bent huh?
      • #4
        Check it as I explained. Only then will you know.
        • #5
          same with prop off 1/2 turn then stops and just hums
          binding some where, will pull armature and check for bends
          • #6
            Did you rull the armature out before you welded the skeg?
            I would woner if the excessive heat from welding could have damaged the field windings?
            • #7
              yes it was taken apart, just the housing was welded on with no electronics included
              Back to Top
