Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
See more
See less
1986 Boston Whaler Montauk Nav. Light Wiring
  • 1986 Boston Whaler Montauk Nav. Light Wiring
    I just purchased a 1986 Boston Whaler Montauk. The nav lights aren't working and the wiring looks screwy. Any OEM wiring diagrams out there? Or, better yet, ideas on how to re-wire with a "pull-pull" switch. I have a bow red/green light, and a stern "all-around anchor" light.
    Thank you for your impartation of wisdom in this matter...
    Re: 1986 Boston Whaler Montauk Nav. Light Wiring
    never mind on this, I bought new tinned copper 16ga, a relay block and found my bow wiring under the rub rail, port side. I temporarily hooked everything up and got it to work. I need to get some more length of wire to finish it up and make it clean, but the "dirty" part is done. Also, my new relay block allows me to clean up some weird wiring that was going on. Now i've got to figure out my gauge issue. Probably have to re-do all that wiring as well. Though it's a lot of work, it's a lot easier than patching, testing, failing and repeating that cycle.
    • #3
      Amen to that. If you have the wiring scrambled, then you spend most of your time searching for what is wrong. Get it clean and it is easier to find.
      • #4
        Sorry you already bought the 16 ga wire. I would recommend no smaller than #12.
        sigpic
        • #5
          You would use 12ga or larger wire on x2 10 watt bulbs? That seems excessive to me. The run from the switch to the terminal block @ stern (for each: the ground and the two hots) is 12'
          The run from the terminal block at the stern to the bow red/green 10watt bulb is 14 feet. Boston Whaler put the wiring (factory) within the rub rail (port side). There is no way you could put two strands of 12ga in there. It just wouldn't fit.
          I think 16 ga is sufficient. I have a fire extinguisher if not.
          • #6
            oh yea, I finished everything up last night. It all works beautifully. I also sprayed all the connections with "Corrosion X- XD" (the green can) for a little extra protection.
            Tonight = clean the high flow jets and check for wiring issues with the gauge harness. Fun, Fun!
