ignition switch for 1979 evinrude
brian1976
I need to no what wires and in what order to wire a new switch to my boat. Can anyone help me?
:confused:
Silvertip
Re: ignition switch for 1979 evinrude
Here are the switch designations and what they are: (this has also been covered before and should have showed up in a "search of the forum").
B = battery + (probably red wire from the engine harness)
S = Solenoid (from the S or start terminal on the starter solenoid). Check the solenoid for wire color.
C = Choke/Primer (activates the choke or primer system when the key is pushed in while starting).
A = Accessory - feeds +12 volts to the gauges when the key is on.
M (two of them) = Magneto - yellow wires that are shorted together to kill the engine when the key is turned to OFF.
RICOSUAVE7777
I Have The Same Problem But, My Swicth Has 2 Red, 2 Purple, 1 Yellow, And 1 Orange. The Harness Has 1 Red, 1 Green, 1 Brown, 1 Pink, 1 Black, 1 Yellow, 1 White, And 1 Blue. WHAT IS THE MATCH, Please Help, This Is The Only Thing Holding Me Back From Getting Boat In The Water.
Thanks In Advance.
