I am about to re-wire my bass boat. Over the years, previous owners have created a snakes' nest, causing all kinds of problems, including a would-not-start on a Search & Rescue practice.
I did a minor re-wire last year, because the new cranking battery kept going down while fishing. So I wired everything off of the trolling batteries except the starter. The cranking battery does nothing but crank the motor. Tilt, lights, fish finders, everything, is connected to the trolling batteries. I also installed a "jumper" switch that will connect one of the trolling batteries to help start the motor. Basically, I wanted to be sure the motor will crank!
Now, I'm going to completely re-wire the boat. What is the "right" way to hook up the accessories? What, if any, accessories should I connect to the cranking battery?
