I have a 20' welded aluminum boat with a single 150hp outboard. During the thief of my batteries someone also messed up the wiring for me. While looking for info about re-installing the battery switch, I came across an article by Don Casey:
?The negative side of the battery should be connected to the hull at a single point. All circuits on an aluminum boat must have a positive ground, meaning two wires connecting the appliance to the battery or distribution panel. The hull must never function as an electrical conductor. A single-point ground connection minimizes the likelihood of that occurring, but you must be vigilant to keep the wiring system in good order on an aluminum boat. Keep the copper cable terminal and the aluminum hull separated with a stainless steel washer to prevent galvanic action between the copper and the aluminum.?
Question: What is meant by -All circuits on an aluminum boat must have a positive ground, and what is the difference between a positive ground and negative ground.
Tanz
Tanz
