Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Depth finder install
  • Depth finder install
    I was wanting to install a depth finder gauge on my boat. I was wondering how difficult it is to install these. Also which would you recommend the transom mount or in-hull transducer?
    Re: Depth finder install
    It’s not bad if you’ve had a little wiring experience. You’ll need to fish wires from the helm to the bilge and you’ll need a 2” hole for the gauge.
    Go here and click on “HDR 610” for mounting instructions for Humminbird’s gauge to give you an idea of the steps involved.
    http://www.humminbird.com/support/FAQ.aspx?faqid=72
    I’d use the in hull mount if your boat is fiberglass. It’ll make for a lot cleaner looking installation and should read fine.
    Bryant 214 Limited/FI 5.7
    Ranger 1850VS/Yamaha F150
    • #3
      On the in hull installation you have to be very careful that you don’t have any air bubbles in the glue between the transducer and the hull. You will get a more accurate reading with water depth with the in hull set up. Depending on your boat the transom mount it’s usually about a foot higher than the bottom of the boat and bottom of motor. Keep this in mind when in shallow water
