Re: Bow Nav Lights Keep Blowing
Shorts don't blow bulbs. Shorts blow fuses. Shock, vibration, high voltage, and cold water on a hot bulb blow the bulbs (which is why one disconnects the trailer lights before backing in the water). Did you actually measure the resistance of the bulbs to make sure they were bad. Simply replacing a bulb in a socket that's loose may make the new bulb work for awhile, but appear to blow when its just the socket that loosens up. This is a new boat so overvoltage should not be a problem as the charging system is well regulated. That should not stop you from measuring system voltage with the engine running at 1500 - 2000 rpm. If its over 15 volts that may be the cause.
