Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
What size nuts for battery terminals?
  • What size nuts for battery terminals?
    Hey guys, I have an Optima Blue Marine battery on my boat, and I want to use regular nuts on the terminals.
    What size nuts will I need?
    The Optima batteries don't have two different size posts for the + and -, like other batteries do, at least I don't believe so, they seem to be the same diameter and thread on this battery.
    Either way I want to replace the wingnuts with ny-lock nuts, as the wingnuts tend to come loose over time. So just wondering if anybody knew the size off hand.
    Thanks.
    Re: What size nuts for battery terminals?
    Take the wing nuts with you. Lowes, Home Depot etc, have a metric and SAE try-out panel. See which one fits and buy what you need.
    • #3
      Thanks Silvertip. Didn't know that Lowes or Home Depot had that, I've never seen it in there, then again I never looked for it.
      Sounds easy enough, thanks for the advice.
      • #4
        Lowes has a an entire aisle of specialty hardware in drawers and bins as you walk in the door. There is a panel somewhere along that aisle with bolts and nuts mounted in a panel that you can try for size. If you can't find it, go to the bins with bolts. Find a bolt that fits the wing nut. Then buy that size nut. Simple huh?
        • #5
          This may sound paranoid, but I bring a magnet (usually from the tool dept.) with me when I buy stainless at HD or lowes. I always double check that the stainless in the bins is actually stainless. Its not that I don't trust the employees, but when you are stocking 20,000 little baggies of nuts and bolts, its not very hard to put one in the wrong place.
          Back to Top
