littlebookworm
- Nov 30, 2007
- 574
Installed shore power in 1986 SunRunner I'm refurbishing. All the equipment came from my previous boat, which was scrapped due to a collapsed keel, but that's another story. Anyway, this time I added a Promariner galvanic isolator. Wired up AC circuits without any problems. Read on internet sites that ouput lead of isolator should be connected both to AC ground circuit panel (which was done with no problem) and to the boat's DC ground bussbar or engine block. The questions I have are: What size wire should I use between the galvanic isolator and the DC bussbar? Is #12 heavy enough or should I go heavier. (AC circuits are wired with #12-3 marine flex cable). What color wire should I use to be safe? I was thinking green because that's the AC ground color and is basically not used for anything DC on the boat. I vetoed black because, even though it's DC ground color, it's also AC positive color and I didn't want any black wires directly connected to the galvanic isolator to avoid any futre confusion. Suggestions/recommendations? Thanks in advance. Hy
