mercury 6 wire ignition wiring diagram w/ push to choke
netminder33
can anyone help me, my ignition went bad and i dont know witch wires are for what. its a 1996 jet boat and i think its a mercury ignition switch, it has these color wires and how can i hook up a rocker switch and a starter button to bypass the ignition switch itself. any info on how to do this would be greatly appreciated.
red
yellow
yellow w/ black stripe
black
purple
pink
Dunaruna
Re: mercury 6 wire ignition wiring diagram w/ push to choke
Somewhere in the eighties mercury standardized their wire color codes, 1996 would fall under that standard. Some of the colors you have described do not correspond to ignition switch wiring.
Red - Battery voltage (unfused)
Yellow - Starter solenoid to starter (yellow/red is switch to neutral start)
Yellow/black - Choke
Black - Ground
Purple - Ignition hot (instruments etc)
Pink - Fuel gauge
steady555
Dunaruna,
Hopefully you're still around to answer this :)
I have the same set up, only I also have a black/red wire. Mercury choke ignition. All the other wires you list seem to line up. I'm thinking the black/red-striped wire must be a ground of some sort, so I should connect it to the "M" - is this right?
Ted
Black - Ground
Pink - Fuel gauge
