cheburashka
- May 28, 2005
- 715
I'm working on a '74 Glassply, Mercruiser 140 i/o. The gauges are pretty simple, but someone in the past rewired them with single-strand telephone wire, and it's starting to get brittle and snap in places. There are all kinds of voltage draws, minor shorts, etc. The problem is, I don't know what the wiring looked like in the first place. So my questions are:
What gauge wiring was used in the first place?
There are really fat resistors soldered into the system for each gauge, and I'm not sure if they were originally there when the boat was built.
What originally came out of the backs of the gauges? Right now it's gray four-strand telephone cable, which doesn't look right at all.
Should I hard-wire the whole thing, or is it best to use connector blocks and bullet connectors to aid in trouble-shooting?
Finally, why the heck would anyone even do this to a boat?
I plan to to re-do this by soldering the connections and using heat-shrink tubing, replacing each connection one at a time. Any tips or hints?
Thanks
Thanks
