I'm having a problem with the anchor & bow lights on a 1993 Boston Whaler Outrage I recently pruchased. I'm suspicious that the wires on the rocker switch may be attached incorrectly. The one position on the switch turns on the bow light - no problem. The other position (NAV Lights - Bow & Anchor) on the switch immediately pops the breaker.
When I disconnect the gray & gray with white stripe on Right Top Terminal (RT) [see below] the bow light continues to work in the one position and the breaker in the other position does NOT pop and the anchor light still does not work.
The anchor light is connected to a black wire and a gray wire with a white stripe. I have continuity on each of these wires (from the switch to the light) and they are not shorted across each other.
On the rocker switch there are six screws. Looking at the back of the switch (anchor-left, NAV- right)I'll reference each screw as follows:
Left Top (LT) - 2 light blue wires jumpered to (LB) with short gray wire*
Center Top (CT) - 1 red wire
Right Top (RT) - 1 gray wire w/ white stripe jumpered to (CB) with another short gray wire**
Left Bottom (LB) - 1 gray wire jumpered to (LT) with another short gray wire*
Center Bottom (CB) - 1 gray jumper to (RT) with short Gray wire**
Right Bottom (RB) - 1 black wire
Can anyone tell me if this is wired correctly. It doesn't look right but I'm not sure how to reconnect it.
I ASSUME that the RED wire is (+, the BLACK wire is (-), the GRAY w/ WHITE Stripe is the anchor light and the Light BLUE wires are the bow light. Is this correct? Why are there 2 light blue wires? These wires are all in a harness and appear to be original.
Does anyone have a schematic for the 17' Outrage? I'd imagine the 18' and possible other models are wired the same.
Thanks
Thanks
