I just bought a used boat (92 Sea Nymph FM160) and I have a simple quesiton regarding the livewell pump switch. It is a 3 way lighted rocker switch. (On/Off/Auto) When the pump is in On mode, the light is lit. When the pump is in auto, the light only is lit when the pump is running. Is this normal or should the light be lit all the time when in auto mode?
The only reason I'm asking is that by not having the light on when in auto mode might cause me to leave the switch on when I pull the boat out of the water. Since I'm in the beginning to mid stages of CRS disease (Can't Remember S%@&) I need all the help I can get.
If this is normal, I'll just try to do my best to remember to check the switch. If it isn't, then I guess I'll need to pull the switch out and see how it is wired.
Thanks
Thanks
