I have a Motorguide Brute 765 24 volt, 50 lb thrust motor with foot control and Dura amp system. The motor when under load will not hold a steady output. The repair shop said that the "mosfet" was very likely to be the problem, and these are apparently no longer available. The shop said that I could upgrade to digital for about $400-450. (This sounds like the movie Robots where Bigwelds new CEO only wants to sell high priced upgrades!!!) Not taking this lying down, I found a string of messages that seems to indicate that these units can be repaired fairly easily according to K-dog...(http://www.wmi.org/bassfish/bassboard/boats_motors/t77809.htm)
The hard part appears to be finding exactly the right transistors. I'm willing to give the repair a try if someone out there can help me find the exact replacement transistors. I have taken the motor apart and found the transistors. I'd be very greatful if any of you would be able to help me find these items?
I found two of the following components: (I believe these are mosfet)
IRF Z44
I R4049
5L 3C
I found one of the following components: (Is this a mosfet, too?)
9040
->|<- MUR
3005 PT
(also stamped with a Motorola symbol and a "France" label)
I found a part that looks very similar and a picture that looks very similar to the first part listed above at the following site,
http://www.mcminone.com/product.asp?..._i d=IRFZ44
Does anyone have any idea exactly where I can find these replacement parts and exactly what to ask for to ensure that I get what I need?
Any help you can offer would be greatly appreciated.
Thanks,
naneely
IRF Z44
I R4049
5L 3C
9040
->|<- MUR
3005 PT
Thanks,
naneely
