Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Windlass Cable Size, 2-AWG or 4-AWG
  • Windlass Cable Size, 2-AWG or 4-AWG
    Hello, I am installing a Lewmar 700H Pro Series Windlass on a 21' CC. My batteries are in the console, so the wire length will be approx 18' to 20'. I am planning to use ANCHOR tinned wire in the 4-AWG size. The installation guide recommends to use 8-AWG size, but West Marine recomends to use 2-AWG size.
    Do I really need to go to a 2-AWG?...as a 4-AWG is already doubling the manufacturers recomendations...thanks.
    Re: Windlass Cable Size, 2-AWG or 4-AWG
    With that long run I would use #2, gg.
    #4 would probably be okay if the batteries were close, but 18-21' is a long run.
    sigpic
    • #3
      Agreed you're running a very long way and operating a high draw accessory you should use #2. Not saying #4 wouldn't work but it's in the gray zone imo.
      • #4
        What's the current stamped on the name plate?
        • #5
          Length of conductors is 40 ft (2 x 20 ft
          Resistance per foot of #4 copper is .000292Ω
          Resistance of 40 ft is .01168Ω
          Current is 35 amps.
          Voltage drop (E = IR)of #4 is .40 volts or 2.9%
          Voltage drop of #2 is .3 volts or 2.1%
          Voltage drop of #6 is .7 volts or 5%
          In other words, with battery at 13.8v, windlass will receive 13.1v. No problemo.
          Personally, I'd go with #6 as it's a very intermittent load.
          Mercruiser trim pumps are also 35 amps, I believe they get only a #10 wire. At 5 ft + 5 ft it's a 5.7% drop.
          West Marine is covering their butt. Extremely.
          Last edited by JB; October 3rd, 2007, 05:55 PM. Reason: deleted forbidden commercial link. See rule #10
          • #6
            Thanks alot guys, lots of great information. Wire2, Lewmar also recomends going with AWG 6 for my application....impressive calculations BTW.
            • #7
              It comes easy for a licensed electrician.
              You're welcome.
