Purchased a boat with an older Furuno CRT radar with a 3.5 ft open array antenna. Crt powers up fine and goes to standby after about 2 minutes. When transmit is pressed the unit dies. Is the antenna the problem? The antenna does not attempt to spin when transmit is pushed. I was going to plug in an operational antenna and see what happens, but I don't want to blow a good antenna. Any thoughts on diagnostics would be appreciated.
