Re: homemade power trim relay
Did your home work for you: Note: W.W. are the initials of Mr. Grainger. Do not confuse with the World Wide Web notation "www".
Switch mfgr: Hubbell
Mfgr P/N: HBL223SPMM
W.W. Grainger P/N: 3D545
Grainger Price (2004-2005 catalog 395) $12.59
Ratings:
DPDT, Spring loaded, On/Off?On; 6 terminals (Push toggle up or down to activate trim and when finished release toggle and it springs back to center which is OFF.)
Max 250V DC; 3/4 HP........@ 741 watts/hp X3/4 HP = 556 watts/12V = 46 max amps per pole set.......far exceeds the 30 amp criteria. Ought to work for a long time.....be sure and save your invoice so if you need to order another, you will know what and where you got this one.
Silicon Rubber Boot (screws on after mounting and covers toggle arm to keep water out of switch:
Hubbel P/N MSB1; Grainger 3JC12; $12 (Ha! costs as much as the switch but you don't want to be without it because water can easily enter the switch mechanism and screw it up in no time.
So for $25 and jtexas' how to hook it up diagram, my man, you are in business.
Grainger is a wholesale house and is a world wide supplier. Phone number is that of your local merchant; they list no 800#. Get the local yellow pages, or go to
www.grainger.com and find your nearest wholesaler.
Ought to be someone you know (if you can't) who can buy electrical/electronic parts wholesale. Usually, if person works for a large OEM manufacturing co, the local Grainger will honor their badge to make purchases.
HTH
Mark
