I have a 14 ft jon I am wiring bow and stern lights from scratch. I am usin a dpdt switch mounted in a plastic project box. I was planning on using inline fuses. My question is all of the info I have read says to connect the ground to the buss bar on the fuse panel, of which I don't have. Is it ok to tie all of the negatives back to the negative terminal on the battery?
