Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Fuel gauge is reversed
  • Fuel gauge is reversed
    New to this board and have never posted before. Have a 90 hp 1999 Honda 4-stroke used and just mounted, gas gauge shows empty when full and goes toward full as you burn gas. Pulled sender wire (pink) off and turned on key, gauge went to full. Any help would be greatly appreciated.
    Guess they are right when thy say a Honda is easy on gas, mine makes gas!
    Re: Fuel gauge is reversed
    swap the wires on the gauge
    • #3
      That won't work. The sender is just a variable resistor. The wiper is one connection and the other connection is one end of the wired core. Reversing them won't accomplish what you need. A different sender that matches what your guage expects will.
      1998 Wellcraft Eclipse 24 Cuddy
      Volvo Penta Duo-Prop 7.4L "LK"
      2006 Sun Tracker Party Barge 21
      Mercury 90 4-Stroke FI
      "Common sense is not very common"
      "Failing to prepare is preparing to fail." -- John Wooden
      • #4
        Normally on a fuel gauge to test it you pull the sender (pink) off the and turn the key on or jumper 12v to the gauge. With no sender wire on the gauge should read empty. Then using a ground wire jumpered over to the S terminal and turn it on again it should full. Sounds like your symptoms are reversed?
        • #5
          What brand is your gauge?
          • #6
            Thanks to all that replied. All gauges are marked on front as Honda. Is there a different type sender unit and gauge for each type of motors and hr power? Did not have this problem until 2000 Jonhson 2-stroke 90 went bye-bye.
            Boat is Lund 2002 Prosport 1675. Bought new show room floor. Gas tank is under floor is 24 gal. Just seems like simple problem, gauge works only in reverse?? Adds gas on gauge as we use it.
            Thanks to all.
            fln
            • #7
              Fuel gauges have absolutely nothing to do with the engine. The sender is in the fuel tank. It has a resistance range of 0 to about 240 ohms. The gauge must match the sender so that means 99% of the gauges are generic. If you have a reverse reading gauge, that says the sender is working. What you have reversed is the +12 and Gnd wires on the gauge. You are essentially measuring a voltage just as you would with a hand held voltmeter. If you reverse the leads on a voltmeter it will tend to read backward. If its a digital voltmeter it will indeed read the voltage but it will have a (-) sign in front of the number.
              • #8
                I would think that guage wouldn't work at all if the power was the wrong polarity. More than likely there is a voltage regulator in the guage that prodeces a reference voltage so that the guage reads the same independent of voltage(ie engine running or not). It puts this voltage across a resistor in the guage and then measures the voltage drop across the sender.
                Did you have a gauge on this boat before and was it working properly? Why did you change the gauge in the first place?
                If you take the pink wire off the sender and ground it, does it read full?
                • #9
                  Bruce...if you read his very first post he said " Pulled sender wire (pink) off and turned on key, gauge went to full." Which is why I stated that's not normal for a gauge to do, at that point the sender is not even in the picture.
                  • #10
                    Ok here is what I have tried thanks to all that have offered.
                    1 pulled pink sender wire turned key on gauge went to full
                    2 reversed grd and +12v wires turned key on gauge went to empty (sender wire on)
                    3 pulled sender and measured wire to grd on guage about 120 ohms (1/2 tank) which is correct
                    4 pulled sender wire off shorted ground on guage to sender lug on guage went to empty. Guess I might try a new guage. Does it have to be a Honda guage?
                    • #11
                      Bob,
                      You are right...at the last second I added that last line without rechecking his initial post.
                      Bruce
                      • #12
                        Some gauges are sensitive and will be destroyed if grounded...try to find a test procedure for the gauge online...
                        Carolina Skiff 178DLV
                        • #13
                          It does not have to be a Honda gauge. There is no physical connection to the Honda engine.
                          • #14
                            If I may, I'll give you the po' boy's fix. Magic marker, change the F>E; E>F.
                            • #15
                              Thanks again for all the thoughts, think I'll do as burroak suggested What would look better pink or blue!!!
                              Keeper full..
