Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Wiring a wiper motor??
  • Wiring a wiper motor??
    First post. Great board and I hope y'all can help.
    I rewired my instrument panel and switches. Problem is, I'm having a hell of a time figuring out how to wire the wiper to my new switch. The only logical wire (to me) to hook up is a white one (which is actually BLACK at the wiper motor) that is hot all the time. When I connect it of course, the switch light comes on and the wiper does not operate. However, when I touch this wire to any other connection on ANOTHER switch (horn for example), the wiper works! What the heck!??
    help......
    Re: Wiring a wiper motor??
    that sounds like a ground for the wiper motor, what other wires do you have connected and to what?
    • #3
      Wiper motor wiring is the same as any other switched device. Hot to the switch. Other terminal on the switch goes to the hot wire on the wiper motor. The second wire on the wiper motor goes to ground.
      • #4
        Thanx for the quick replies. I wish it was like other accesories, but it ain't. LOL
        There are THREE wires from the wiper motor. One is red - goes to the fuse panel (+ pos). Another is blue and goes to the fuse panel (neg -). The third is the black which is hot all the time. As I said, when I connect it to the switch, it lights up the switch LED, but doesn't work the wiper. Only when I touch it to another switch, does it work. I'm assuming that the third wire is to "park" the wipers? What a PITA this is....
        If I could get a schematic for a single speed wiper....
        thanks again.
        Chris
        • #5
          red to swiched + / black to - / blue is for park
          • #6
            Look at this link, even though it's for a 2 speed motor it clearly shows the conenctions for the red, black and blue.
            Wiper Motor
            • #7
              Oook, red and black are a no-brainer; where does the blue wire connect ... ?
              • #8
                Blue is park so in order for it to park the wiper after you turn it off it needs to be hot all the time so it goes to an unswitched 12 volt line.
                • #9
                  Still no joy. As stated the blue wire is grounded and the black wire is hot all the time. I managed to get the wiper to work, but then the LED won't light. I didn't change any of the connections except the black. the other two were connected this way and my wiper worked. The only difference between my prior setup that worked and my present one, is that my new switch has an LED. The other switch did not. I cannot find a schematic for hooking up a wiper to a LED swiched panel with breaker. The hot wire is throwing me off! I may have to go to an electrician, which in all my years of wiring car stereos, lighting etc, will be a first for me.:'( I'm stumped.
                  • #10
                    What do you mean the black wire is hot?
                    do you have any test clip leads laying around? Forget the switch for the moment. Hook up a ground to the black. Hook up 12V to the blue...What happens then? Now add another clip lead to the last wire from 12V and see what happens.
                    Once you have that figured out you can worry about your switch.
                    1998 Wellcraft Eclipse 24 Cuddy
                    Volvo Penta Duo-Prop 7.4L "LK"
                    2006 Sun Tracker Party Barge 21
                    Mercury 90 4-Stroke FI
                    "Common sense is not very common"
                    "Failing to prepare is preparing to fail." -- John Wooden
                    • #11
                      If the new switch has an LED or light and the previous switch didn't then the switch now needs a ground wire for the LED to work. Follow Bruce's idea and hook up the wires temporarily the way they should be to prove the wiper motor is OK and then wire up the switch. Just curious how many terminals are on the switch? Is it just an on/off switch?
                      • #12
                        When I say "hot", I'm not referring to temperature - it has power.
                        None of the previous switches had led's, but the gang panel I bought has the grounds and all the other switches are working. Again, it's the hot wire that's throwing me off. Usually the black wire is a ground, and I'm having to rethink everything.
                        Yes, the switch is just an on-off and I have lots of test leads, multimeters etc.
                        Thanx Bruce and Bob!
                        • #13
                          forget how it is connected now, lets rewire it like this, black connected to ground, red connected to a switched positive blue connected to positive, if it happens not to work in that manner try switching the blue and red
                          • #14
                            The back of your switch may look like this? but you can see that there is a need for a ground to make the LED work, the middle term should have +12v and the load should be the red wire going to your wiper motor
                            • #15
                              Understand that after you connect the red wire to a constant +12V, the unconnected black wire will indeed be "hot" until you ground it. (Ohms law, no current etc).
                              Do as the others say, wire it up directly without the switch and analyze what happens.
                              CD
