My speed indicator has stopped working ever since the boat released from its mooring and drifted onto the sand for an extended time. The boat has an external sensor which is a plastic wedge at the bottom of the hull. This sensorappears to operate on a vacuum or difference in pressure since it is attached to a plastic hose rather than electrical wires.
I checked to see any obvious signs of sand plugging the sensor, but Is it possible that the sensor is plugged deeper inside.
Are there any other things I can do to troubleshoot the problem, in particular to see if the guage on the dash is working properly?
thanks for any help
thanks for any help
