Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
See more
See less
electrical grounding to aluminum hull
  • electrical grounding to aluminum hull
    I am rewiring my aluminum boat. Should I ground the hull? I was thinking about running a wire from the negative side of my battery to a buss under the dash for my accessories.
    Thanks
    Bill
    Re: electrical grounding to aluminum hull
    If you wan't a corrosion magnet... yes
    • #3
      [colour=blue]Don't use the hull for ground, but bonding is o/k - depending on a few factors.
      Watch this space......................
      • #4
        Saltwater usage being one of those factors.
        The wetter, the better.
        • #5
          I would not use the hull to carry any current but to ground the engine to the hull is normal.
          I do not know about outboards but I do not think you will find an I/O that does not have some part of the engine bolted to the hull.
          Have some fun and enjoy the Great Outdoors.
          Love to fish out of Bodega Bay, California.
          • #6
            Current flowing through electrical connections, in particular dissimilar, metallic, electrical connections, causes electrolysis which is corrossive and destructive. A salt environment highly accellerates the process.
            To reduce the occurrence, the system needs one grounding point which is usually the neg batt term, where everything is connected in parallel Meaning separate wires go off to all the separate functions. Best to supply power the same way from the + terminal.
            The dashboard electronics can all be connected to an isolated (from the metallic hull) buss "terminal block" with one for + and another - power connections with a single wire (from each) representing the dash going back to the battery.
            Since the hull is metal I think it prudent to "safety ground" if you will, it to the single point neg bat term. If you let it "float" you never know when or if a static charge would build up that would be similar to a lightening bolt and the spark could destroy something sensitive (I realize the intensity is no where near as high, but the principle is the same; however, a distant lightening strike from a squall could trigger just such an event.).
            The engine is bolted to it and already serves as a safety ground for it but you might want another dedicated wire.
            Mark
            If you are new to boating or have a new boat, a knowledgeable friend could show you how to operate your boat and save you a lot of grief, maybe some money, and maybe your life.
            • #7
              Mark,
              Thanks for explaining it to me. I was having a difficult time understanding why you should not ground each item under the dash directly to the hull since the motor is grounded just by its presence on the transom.
              I will run dedicated wires to the terminal blocks under the dash and make my connections for lights, depth finder, ect. at that point.
              I also recieved some (mis?)information regarding electrical current from the hull affecting the fishing while trolling.
              Bill
              • #8
                I spent many 10's of years working problems just such as this one on very high dollar toys, er ah things. Have a little training and experience.
                What we are talking about here is called "single point chassis ground". And what it does is insure that a piece of equipment isn't powered/signaled on a line powering/signaling another piece of equip which could inject noise into the second item on the line.
                What do you mean about current affecting fishing while trolling?
                Mark
                • #9
                  One more thing Bill,
                  If, for some reason you have interference on any of your dash electronics and by turning things off till the interference leaves you find something is the culprit, you can place a condenser (capacitor) across the + and - terminal blocks.
                  Radio shack has them; a .1 microfarad cap at 50 or more WVDC would do nicely. Will be about the size of a nickel. What it does is short circuit high frequency signals right at the terminal blocks so that they can't get out of the power lead of one piece of equip and get onto the power leads of another.
                  But, don't mess with it unless you have to and be sure it's electronics, not bubbles from the boat in the case of depth finder interference.
                  Mark
                  • #10
                    [quote ]
                    [/quote]
                    The motor is not grounded to the hull, it is bonded. They are 2 different things. You don't want your hull to be an electrical path to any device. Run individual ground wires to a grounding block and then run a single ground wire from that block to the battery if you have a lot of instruments/devices.
                    As far as the whole lightning protection thing, a bonded motor or device to hull will not make a difference. Most people think a lightning rod on a house is meant to let the lightning hit it and send the lightning to the ground "safely".. not true. it exists to eliminate the build up of a charge in the first place which attracts lightning. If your house or boat is hit by lightning (directly) or very close vicinity no amount of grounding or bonding will help you.. the voltage and current of a strike are enormous.
                    • #11
                      You want them to remain at the same potential so that static electricity doesn't develop. You are moving a conductor (boat hull) through a dielectric medium (water) which develops static electricity. Improperly allowed to develop it can charge to thousands of volts and ruin the best electronics (if not protected against it).
                      Agree on the purpose of rods on a house.
                      Don't know your distinction between gnd and bond (with respect to the engine); both are synonyms.
                      The engine is electricaly tied to the batt for power and power return (hence ground) through the engine's wiring harness. All the electronics in the boat and anything else electrical is driven from the battery....unless you have a dedicated APU like you'd have on a large boat.....then the APU is the point source.
                      Therefore, since the batt is the origin of power, the battery is the best place to "reference" all electrical currents. Tieing off to the hull is just "referencing" the hull to the single point power source......that everything else within the hull if referenced to.
                      Any technical library should be full of EMI (Electromagnetic Interference) facts and avoidances.
                      HTH
                      Mark
                      • #12
                        Thanks for your input Mark & b00t.
                        I notice on my boat that the bilge pump which is grounded to the hull at the transom is operational which indicates to me that the hull is grounded even though I have no other connection to the battery except the engine -- I have not yet run a dedicated ground wire.
                        Also, in the past I have had interference on my depth finder when the engine is running (could be bubbles you mentioned) or when I am near another boater who is running his engine or depth finder ---- will the condenser (capacitor) you mentioned eliminate this (assuming it is not bubbles)? Is it placed on the culprit wiring or the depth finder?
                        Finally, I have been told that any electrical current through the hull (static electricity?) might make the fish less willing to bite! (even though I am willing to take full responsibility for not being able to put fish in the boat!!)
                        Thanks again for your information
                        bill
                        • #13
                          Maybe that's why I don't catch fish, I have electrical current in my hull. I'm going to use that excuse anyhow, now if I could just come up with one for why I can't catch them from the dock either! 8)
                          • #14
                            Fish are sensitive to electrical charge, some species more than others, and who knows how much is too much, but taking steps to minimize your electro-magnetic signature is more than mere superstition (at least I think it is).
                            BTW, I can't quite put my finger on it, but "static electricity" somehow seems inconsistent with "electrical current"...
                            It's all about the tools.
                            "If the ocean is glass flat and the sun is shining, you open up the special memory compartment of your brain and start recording the smells, sounds, sights and feelings." -- Philster
                            "Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
                            • #15
                              [quote ]
                              I notice on my boat that the bilge pump which is grounded to the hull at the transom is operational which indicates to me that the hull is grounded even though I have no other connection to the battery except the engine ... in the past I have had interference on my depth finder when the engine is running ... [/quote]
                              I would like to re-iterate that the wire between your engine block and your boat hull is used as a bond not a ground. All motors and instruments should have a direct path to the battery negative, not through the hull. There is no "ground" on the hull, only a poor path back to the only real ground (the battery negative).
