Re: Standard Horizon Depth sounder trouble
Clean the transducer. Scum and crud can affect readings. Disconnect the transducer cable at the head unit. Check it for corrosion. Check transducer resistance. I have no idea what it should read but it would likely be quite low. If it shows open circuit its probably toast.
