Re: Mounting Two Transducers Close
chad,
get a 2nd one with a different frequency from the first. Otherwise, put one 'ducer on the trolling motor and one on the transom; if your boat is long enough, and the water isn't too deep, and if the sensitivity isn't set too high, you won't get interference. And if you do, just turn off the console unit when you start fishing - the one on the t/m won't interfere while it's out of the water.
