gergAlicious
- Jun 25, 2011
- 53
My bilge pump works with the dash switch. So that side is fine.
The float does not operate it however. I have verified the switch at the float is good. I also have 12VDC going into the switch.
I disconnect the float wires @ harness and jumper the leads and nothing happens - jumping towards boat as switch would do.
I expect this is an accurate example of my wiring as I DO NOT have a three way switch at the dash.
My only suspicion is that 12V from the float switch is not making it back to the splice / union as depicted above. 12V from float and 12V from switch connected just above the pump in that diagram.
Am I on the right track?
Thanks!
Thanks!
