Grub54891 - You guessed correctly. I burned both my batteries down to about 40% last Saturday using my 24 volts wireless 75 pound push Motorguide trolling motor trolled all the way home for 1 to 1.25 hour at top speed. (3 to 4 miles) The voltages were 11.8 and 11.6 after I got home. I have been trickle charging them for the last 4 days. It went up to 11.9 volts from 11.8 v and didn't even get to charge the other one. I think they are both dead. Do you agree?
I decided to buy 3 new batteries. (1 start and.2 deep cycle)
I had 2 marine batteries for my boat. both bought from Advance auto parts. The first one was bought in 2014, group size 31 dual purposes. The second one was bought in 2015, group size 29 HM and deep cycle.
The marine starting battery I picked up today from Advance Auto parts is 24M 500 CCA. I was able to start my Johnson 90 v4 cross flow, and ran the motor for 8 minutes in idle speed. The motor shut off by itself. I tried to start it but unable to start it. I checked the voltage of the new battery after a few cranks. It was down to 12.0 volts??? Crap!!!
If I have the jump starter with me, then I CAN jump start my Johnson 90. If I had it with me at my Saturday trip, then I would have saved my 2 big batteries (almost $200) because I could jump start my Johnson 90 and got home with it instead of running the 24 volts trolling motor.
So, time to buy a jump starter --- Lesson learned!!!!
The new battery came at 12.2 volts (ONLY 60% charged) even after I specifically asked the clerk whether it was fully charged. And he replied YES! ???? I should have insisted asking him to show me 100% charge with a volt meter.
I will bring it back tomorrow and bring my own volt meter with me to check the replacement.
AutoCraft Marine and RV 12-Volt Starting Battery, Group Size 24M, 500 CCA
SPECIFICATIONS
Battery Type: | Lead Acid |
BCI Group Size: | 24 |
Cold Cranking Amperage: | 500 A |
Cranking Amps: | 625 A |
Height: | 8 11/16 in |
Length: | 10 15/16 in |
Maintenance Free: | Yes |
Reserve Capacity: | 95 m |
Terminal Type: | Combination Auto / Stud Terminal |
Voltage: | 12 v |
Weight: | 39 lbs |
Width: | 6 7/8 in |
