Pusher
- Sep 2, 2014
- 1,273
I need to wire a 3amp water pump to run off of a standard household outlet. It will eventually run through an inverter, but for now I'm testing it on a household outlet.
I bought a cheap extension cord and cut the female terminal off. I then installed an in-line 3amp fuse followed by a rocker switch to the water pump.
The 3amp fuse blows when I plug into the outlet. I tried stepping up to a 5amp fuse with the same result. Do I need to step down the power source with a 30amp in-line fuse and then again to the 3amp? I'm not sure how the available supply versus the draw of the accessory works with fuses.... and I guess electricity in general.
