1999 Merc 150 XR6 Ignition Switch
Knottymate
Can someone give the ignition switch part number/model etc for a Carb XR6 150 with push in Choke
The current 18 year old switch spring will not let the key stay in the run position and flips left to the off position
Knottymate
Thank You sam am I, that looks like what is on there. Other inquires showed wire lead outs which meant
soldering etc. This will work much easier. Thanks again
