67 OMC Sportsman 120 if it's relevant somehow.
Last week I went to tighten a positive nut under the helm and accidently hit the ground. The wire I was tightening is the main power wire to the helm from the distribution block on top of the engine. For what it's worth I thought the battery was disconnected when I was tightening the nut. So, when I touched the ground I got a nice spark and immediately pulled the wrench off. After that I noticed that all of the positive wires had continuity to ground. I was trying to narrow down the source of the short and decided to pull both wires off the battery, no more short. I do, however, have continuity between the positive and negative battery terminals with no wires connected. Is it possible I somehow shorted the battery itself?
There is supposed to be a 50 amp fuse connected to the main positive wire of the boat but I'm assuming the previous owner removed it since there isn't one.
This is based on my assumption of no continuity without the cables connected to form a circuit.
What I did notice is that with the positive cable connected to the battery and no ground connected I have a short in the positive wires I tested.
