Hey guys,
I just bought a 2004 Crestliner 1600 with 50hp Yamaha 4 Stroke as my first boat.
I got it as a fixer upper and am currently running into a pretty bad electrical gremlin.
The boat starts/runs fine. The Fish finder on the dash works as well as the Yamaha motor Tach that is installed.
- The boat Speedo does not work
- The boat CD player does not work
- There is a 3 gauge cluster on the dash for battery voltage, fuel level and engine trim. All 3 of these gauges read zero. There are however several toggle switches on this panel that work and light up properly.
The battery is putting out 12.7 Volts
There is a fuse panel underneath the dash with a multitude of fuses but none of the labels seem to have anything to do with the gauges. There is 12 volts going into the panel and I checked all the fuses and they work fine.
Can anyone point me into a direction to look next?
Thanks
Thanks
