OK, I have a BatteryMinder 1500 (1500ma) with desulfator. I have a deep cycle trolling motor battery that until now, I just used the BatteryMinder 1500 on between uses. However, I am taking the canoe and trolling motor camping in a couple days and play to use it several days in a row which will require fully charging between uses. My question is: If I drain the battery down to 1/2 or 1/4 capacity one day, will the BatteryMinder 1500 enable me to charge it over night to a full charge for the next morning...Lets say 12-16 hours? Or, would I be better off bringing the Schumacher 1275a - 2/12/75 and use that overnight? I am thinking I will need the 12 amps of the Schumacher to get it fully charged over night but would rather just be able to use the BatteryMinder 1500 if that would suffice.
The battery is a 105 AH battery if that matters.
Second follow on question, should I ALWAYS use the Schumacher between uses to bring the charge back up quickly or is it OK to just put the BatteryMinder on it and let it take it's time topping off the battery?
Thanks for any advice,
Bruce
Bruce
