I recently picked up this boat in need of some fixing up. I have been trying to find some diagram or information for the wiring as much of it was chopped out of the boat. the johnson 70 outboard is still wired up and has the harnesses leading well into the hull, but then it is chopped. I have figured out most of what things are except for two bundles of wire that i assume involve ignition ect. Any help with diagrams or info as to what needs to be tied to what would be greatly appreciated. I have two wires as of now that come off the back of the throttle and go nowhere. I also have two bundles coming off the motor with the following wire colors ( black, black/yellow, yellow/red, grey, red/purple, purple/white, tan, purple) and second (red/white, green/white, white/brown, black/brown, blue/white)
any ignition switches, solenoids ect. have also been removed. Thanks
