Thanks for the reply I downloaded the manual when I first got the the boat but as you say OF SORTS, I have electronic ignition on it at the moment and it has been working fine up until last weekend and then would not fire up that is when I checked the coil etc and found I only had the 4 volts to coil.
Job for the new year I will test it out with a separate wire run from the battery to see if it will start and yes I know I will have power to the coil permanently but as I said I will only be testing for starting and I will then remove the wire and do a proper job
