I'm installing an isolation transformer on a vintage 40 foot Chris Craft. Currently, boat has a port and a starboard shore power receptacle, each 30A. AC panel has a breaker with polarity indication for each shore power connection with a lockout slider that only allows on shore connection at a time. Currently, this boat has no ECLI, but has a GFI at every AC receptacle.
The ABYC standards state you need an ECLI:
"11.11 GROUND FAULT PROTECTION ? AC
1.11.1
An Equipment Leakage Circuit Interrupter (ELCI) or Type A Residual Current Device (RCD) shall be installed with or in addition to the main shore power disconnect circuit breaker(s) or at the additional overcurrent protection as required by E-11.10.2.8.3 whichever is closer to the shore power connection.
EXCEPTION: Installations where an isolation transformer is installed within 10 feet (3 m) of the shore power inlet or the electrical attachment point of a permanently installed shore power cord and supported according to 11.14.4.1.3"
As both shore power receptacles are within 10 feet of the AC panel, does this mean I do not have to install an ECLI if I have an isolation transformer?
Thanks,
...bill
1.11.1
Thanks,
...bill
