Hello everyone! I am pretty new here, and a novice, so I hope some of you might be able to help me. I have a 16ft Lund deep-v with a 20hp Yamaha 4 stroke motor.
I have installed navigation lights (both bow and stern lights) and wired them to a switch panel using 14 gauge wire. In addition, I added LED strip lights for the interior of the boat, and wired all of them to a switch panel. The back of the switch panel has all of the positive wires connected to it from the lights, and all of the negative wires from the lights are connected to a bus.
The bus has a positive side, and a negative side, and the top screw of each side of the bus is connected to a wire going to the battery. The positive wire going from the bus to the battery terminal contains a 7.5 amp fuse.
When this is hooked up to the battery, everything works fine. Today I hooked the motor up to the battery as well, and when it is connected, the 7.5 amp fuse keeps blowing.
Any ideas what would cause this?
Thanks in advance!
Thanks in advance!
