It's not as complicated as you may think to install it in the engine room. A charger for that size boat is not that big, And if you get a guest smart charger, or similar unit It's a sealed unit, no sparks involved. Install it in the battery area, no need to lengthen the cables unless one battery is on the opposite side from the other one if you have 2 batts. The engine room is already vented so no overheat issues when using it. The engine room may look like a lot of stuff is crammed in there, and it is, but usually there is space for a charger. Install the shore power unit in the cabin area, on a small breaker panel run wire to the charger. just keep the wiring tied up neatly from any moving parts and good to go.
