trim wires
I have four wires on the engine end of the harness meant for the power trim, Tan with female connector, blue and white, green and white, and brown and white all with males. the engine has a blue and white, a green and white and a solid red. Please tell me which ones are connected together, I have tried different things but when I press the switch all I hear is the solenoid click but no motor. all was well till the battery shorted out against the frame and fried the ground wire in the harness from the engine to the control box. I now have a new harness and it is installed and these are the problems I'm having. Thank You.
