Harvey Manfrenjensenden
- Jul 21, 2016
- 10
Hello all, well this one is really throwing me through a loop. The only way I can describe it is through a link to a YouTube video I uploaded so you can hear it. It's a bit louder on video than in reality, but you can still hear it from 20' away, and when it's in water it resonates through the head unit even louder.
Here's the video:
https://youtu.be/E3lzkik-L9w
- 2010 Motorguide Pro Series 75# 24v (I'm ready and waiting for the "shoulda bought a Minn Kota" comments haha)
- this video is taken without the prop on
- commutator is clean, no flatspots although there is one pin-sized chip in it, but I bought this second hand and for all I know it's always been there (chip doesn't look new by any stretch)
- brushes are clean and smooth
- magnets are intact, no cracks and are firmly in place within the unit
- I've tried a very thin coating of grease in the bushings at both end caps
- I've tried rotating both end caps, and although it changes the tone slightly, it doesn't do much
- the shaft is straight, no detectable fluctuation or wobble
- the inside of the unit and the electronics are very clean
- batteries are just shy of two months old, optima blue-tops fully charged
- motor is wired to the console, 6ga wire to a plug with 6ga adapter (the wires both at the battery and at the plug are quite cool to the touch. After about 5 minutes of runtime out of the water, the lower unit gets pretty warm to the touch, but I'm guessing that is somewhat normal)
It started doing this about 2 weeks ago, after putting a new prop on it. Prior to the Machete III, it had a Hydrazilla Hacker on there, which was a much bigger and heavier prop, so I'm not sure if the motor developed a load memory due to the prior resistance. It was on there when I bought it a few years ago, I don't know how long it's been on there in total. That being said, it does this now with or without a prop on it...
Has anyone here come across something like this who can think of something I might have missed, or have a better idea than what I've already tried? And guys, if I even thought I could afford a new Minn Kota or something else right now, trust me... I would have done it instead of posting a long winded violin playing sob story
Here's the video:
