volleybiggs
- Mar 26, 2011
- 37
When I start the engine I blow the main fuse that controls all electrical. When I replace the fuse it will sometimes it will start. By mistake I left the key in the run position and when I put in the fuse in I could hear like a an electrical burn sound. I was on the lake and had to change out 4 fuses before it would start. Also I guess it is a lose wire. This is the second time i took the boat this year. Last year the last day i took it out I hit some big waves it cut off and did the same thing. I checked the wireing harness fuse box and it was loose so I screwed it back into place. Not sure it if it lose wire there or the ignition key starter. Thanks in advance.
